Last night I just got done replacing my injector and went with some 190/30 turn key 5 or 6 times in on position truck started after 30 seconds off cranking took it for a test drive everything was all good.
Went to take it home and truck started to over heat and the "check gauge" light comes on truck is in the red I pulled over let sit on freeway. Now the engine light was on saying injector 1 circuit low and low intake pressure I think was the second one.
When I had it apart I replaced the thermostat 1 because it was stuck open and 2 the o ring went bad. I replaced it with a Napa brand? Was this a bad idea?
What could be the cause of it over heating?
Also what action should I take about injector 1 circuit low? It does sound like its missing?
Truck has only started 3 times since new injectors.
03 f250 6.0 Sct with innovative tunes 5in exhaust coolant filter blue spring 6in lift 20x14 on 37s
