Ive tried to search it here, and also on Google, and come up dry.
My brother has a 96 with a ZF5 2WD and is looking at swapping in a 4R100 out of a 2000 2WD. I know that the trans should bolt up, and may have to do a little driveshaft modifications.
Would probably trade PCMs with the swap as well to get that out of the way, will that work?
And is the wiring for an auto also run under the truck, kinda like plug and play?
Will probably just rig up a floor shift for now, and a LED on the dash for the OD light.
Would get it retuned also. Is there anything I have overlooked, or is that about it?
