Dieseljunkie
So I had to get an orileys alternator saturday. I was in a bind and couldn't wait for ford to open or to order one off line. It seems to be a pretty good unit, its the ultima select 110amp. Well I put it on and it wasn't charging so I wiggled the pig tail and I heard the pitch of the engine change and it started to charge. When ever I start it now it stays around 11.0-11.8 volts unless I drive it for a while at a higher rpm range. Could the bad pig tail be causing this or is the alternator just junk? On a 2:30hr drive yesterday it was charging good 13.5-14.6 volts.
