psduser1
So I'm putting together another 7.3 farm truck....
I picked this up from a buddy, he pretty much built it the way I would, performance-wise. Unfortunately, his Pyro was after the turbo, ended up burning the valve off one the #1 cylinder, trashed the piston, etc.
300k on the block, not worth it to me to rebuild, as I have another sound-forged rod-block in an 01.
Swapped engines, new springs all the way around, new rubber, and swap the performance parts to the new engine. Tig welded the pickup tube, cleaned and painted the oil pan, and rebuilt the oilcooler.
While the cab is up, I'm adding a di regulated return, eliminating the fuel bowl and a bunch off leak points on the stock fuel system. I build my own pump and filter setup, with a single pump. Hutch and harpoon mods also, of course.
On the air side, 38r and delete pedestal should cure a couple of oilleaks!
Auto trans, with a 6.0 trans cooler.
This truck already has php tunes, to run the 200/100% injectors. Hpop is-gasp- an srp 1.1, lol:flipa:
Big aluminum flatbed, 5th wheel hitch, airbags, dana 80 rear axle with 4.10s, I think it'll make a decent work truck.
