Nice forged rod 7.3 shortblock
rpm-inc
Out of a 4300 series truck. Was told it had 70k, and I believe the guy. Perfect crosshatch, and no ridges. Cam and lifters. No front cover. Has a junk oil pan with a couple bolts so it can sit on a tire. 475 obo. Pick up only at 60185 near Chicago.
rpm-inc
Need it out of the way and getting tired of spraying the bores with wd40!
rpm-inc
Nope. Bought it as a short. I have another high mileage 01 longblock if you need some heads.
EDIT-Yes I still have it.
Milford
Plainfield, IL
I have long block but its all torn down to bare block, really I have everything for a motor sitting around minus injectors, HPOP, and components for a turbo pretty much. I just want to get a forged motor in my PMR truck so I can get some injectors worth buying and not worry about my motor coming apart. What do you want for the short block and in your opinion, would this thing be a strong motor or what? I don't want to spend the money on a rebuild kit and machine work.
rpm-inc
I bought a 94 from vegas with engine problems and had it shipped. I assumed the worst and the engine was low on compression. While it was in transit, I bought this shortblock for it. Turned out 94 only needed injectors and compression was good. So I had intentions of using it. Shortblock looks great. I would use it if I needed it.
