Lmgrpowerstroke
Started the truck yesterday and was fine. Today go to start Turn the key and nothing. Everything works in the truck Tested batteries and they are great. Checked fuses with nothing blown. Any thoughts from you guys
WTS light on? Didn't blow the fuel heater fuse did you?
Unplug EBP sensor and you can also put shifter in neutral to see if it cranks
