No high end power
Mesa, AZ
Use a chrome socket too. They dont give like impact ones do and have less of a chance of rounding the nut when you whack it.
jordysoso
Nowhere
Ok thank you will do!
If replacing this sensor doesn't work, where should I look next? When the torque converter locks I've noticed that with the the rpm drop, it will hold 30psi for a second or two then drop down to 15-20 ish.
jordysoso
Nowhere
I may have found a boost leak at hot side intercooler boot, showing signs of air/oil making its way past the seal. Can't test drive it tho bc now I have a leaking radiator and lower driver side corner.
jordysoso
Nowhere
Radiator replaced, pulled intercooler boot, I have coolant mixed with CCV blow by residue on the intercooler pipe.what could this mean? Bad turbos or fcked gaskets? Still not throwing any codes.
jordysoso
Nowhere
well water of some sorts, not sure that it is coolant, didnt taste it.... its hot side pipe. or is it normal... ill try to post pics
jordysoso
Nowhere
Pics...
