so bought a truck cheap oner said it needs a motor it was idleing and just quit and wouldnt start again so i think hpop . so i try to start it with dead battrys and a jump box and another 2003 6.0 truck turns over and makes oil pressure and almost starts but just smokes bad bad whit smelt like fuel bad so i guess its glow plug related.... then today i get the new bats in it and it starts and runs rough as hell so i see if it will smooth out since its around 18* out . truck idles up to aroound 1500 then to 850 then 1100 and back down all over the place. then dies and wont start. look at op gauge and no oilpressure on gauge . while truck was running it had good oil pressure (or the same as my running 03.) oil is also full on dip stick. so i pulled codes and got a
p0603 internal control module keep alive mem. malfunction
p0670 glow plug control circit
p0673 cylinder 3 glow plug control circut
p0683 glowplug control module to power train control module mommunication circut
p1000 on board diognostic II moniter/drive cycle test not compleat
but no hpop codes? work your magic psa thanks for any help
