f350BeastinmaKing
05 f350 6.0 srw
it started injectors making noises after I got fuel from a gas station I normally don't go to. then I put some diesel 911 in fuel thinking it help it didn't, so I changed fuel filter and then after 10 miles it felt great. turned off then on and made funny noise at injector location. while driving I noticed allot of white smoke coming from tail pipe, then on dash turbo pressure was at 40 redlined and no oil pressure on gauge I shut key off and pulled over carefully and got towed. what do you think this is im leaning towards bad turbo or hpop. but im fairly new to the 6.0 so please inform other things I can look at. I looked underneath and there is nothing dripping anywhere, on area I see wetness is by back exhaust manifold driver side only a wet spot but not like a huge leak.
