Oasis report please
patk
Seattle WA
Hi Folks... new to the forum at the suggestion of my son. I'm looking at a 2003 F250 ext cab lariat with 82K miles and would greatly appreciate an Oasis report if someone can help me out.
The Carfax shows the dealer serviced it regularly up to about 59K miles.
VIN: 1FTNX21P73EB93506
Thanks
psdparts
Nashville, TN
Thanks
OASIS RESULT: 1FTNX21P73EB93506 USA: EN-US 25-MARCH-2013 / 08:39:03 EST/ APP1
Local Time: 25-MARCH-2013 / 7:39:05 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2003 F-SERIES BODY STYLE: F-250 SUPER CAB 4X4 ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque AXLE CODE: C1 ENGINE CALIBRATION
PAINT COLOR: ARIZONA BEIGE PAINT CODE: AQ RADIO: AM/FM CD Changer/Clock
AXLE RATIO: 3.73 Ratio WHEEL SIZE FRONT TIRE: LT265/75R-16E OWL A-T Tire
GROSS VEHICLE WEIGHT: 8800 LB. GVW
WARNING MESSAGES
Click here for CUDL
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
ACCURATE REPAIR NOTIFICATIONS === more than likely a ford buy back?
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE: 24-MAY-2003 BUILD DATE: 17-JANUARY-2003 SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
FULL WARRANTY HISTORY
AWS Claim Key
Trx Code
Time In Service
Labor Hours
Dealership
DIST (Miles)
Repair Date
Prefix
Base
Suffix
Doc
Details
1088961
03B06
DISCOVERY FORD LINCOLN
352
30-APR-03
09356202
Customer Comments
Tech Comments
Details
1088960
03B05
352
30-APR-03
09356201
Customer Comments
Tech Comments
Details
1820523
ALL STAR FORD
1835
16-JUN-03
F81Z
28253A36
AA
07253403
Customer Comments
RR DOOR W STRIP STICKS OUT AT TOP
Tech Comments
REPLACE RR DOOR FRONT W STRIP
Details
1820524
ALL STAR FORD
1835
16-JUN-03
RECAL
07253401
Customer Comments
CUST STATES IDLE FLUCTUATES AT TIMES AT STOPS.HOT OR COLD ENGINE.
Tech Comments
ROAD TESTED EEC TEST MONITER PID DATA..CK OASIS CALL HOTLINE. .REPROGRAM MODULES..TO LATER CAL,
Details
2610998
ALL STAR FORD
4726
05-AUG-03
DIAG
07527804
Customer Comments
CUST STATES IDLE FLUCTUATES UP DOWN AT TIMES WHEN COMING TO A STOP AFTER SHORT DRIVE IN AM
Tech Comments
CK OASIS ROAD TEST..INSTALL WDS AND EEC TEST..CK FOR LATER CALIBRATION.HAS MOST CURRENT CALIBRATION AT THIS TIME
Details
2630333
5.5
ALL STAR FORD
4726
05-AUG-03
3C3Z
6701
AA
07527805
Customer Comments
OIL IS LEAKING AT REAR OF ENGINE NOTICED IN SHOP ON HOIST
Tech Comments
ADDED OIL DYE POSS LEAK AT REAR MAIN SEAL NEEDS DYE LIGHT TESTED
Details
2611000
.6
ALL STAR FORD
4726
05-AUG-03
54045A36
07527801
Customer Comments
CUST HEARS A RATTLE FROM DASH WHEN DRIVING REFER TO HISTORY FROM LAST RO
Tech Comments
CK NOISE.ROAD TEST.REMOVED RADIO.INSTALLED ANTI RATTLE FOAM BETWEEN HEATER TUBE AND DASH
Details
2610999
57B98
3
.5
ALL STAR FORD
4726
05-AUG-03
07527803
Customer Comments
CHANGE OIL & FILTER, LUBE CHASSIS AS NEDED, CHECK & TOP FLUID LEVELS, CHECK AIR FILTER, CHECK AND SET TIRE PRESSURES
Tech Comments
1 CHANGED OIL & FILTER, LUBE CHASSIS IF NEEDED, TOPPED FLUID LEVELS AND SET TIRE PRESSURES.
Details
5768689
E84
12
.9
ALL STAR FORD
14841
30-APR-04
3C3Z
9B249
AB
08964101
Customer Comments
CUST STATES WATER IN FUEL LIGHT STAYS ON,CUST DRAINED WATER 2 TIMES AND LIGHT WILL GO OFF BUT COME BACK ON
Tech Comments
CK DRAINED WATER ..LIGHT OFF THEN BACK ON..TEST SENSOR RR WATER IN FUEL SENSOR ASM, RE CK OK..
Details
8058833
04S15
17
.4
ALL STAR FORD
20312
15-SEP-04
09673205
Customer Comments
PERFORM SAFETY RECALL 04S15, NEGATIVE BATTERY CABLE ENGINE TO BLOCK CONNECTION.
Tech Comments
1 REPAIR AS PER RECALL GUIDELINES
Details
8077772
E84
17
.5
ALL STAR FORD
20312
15-SEP-04
DIAG
09673204
Customer Comments
CUSTOMER STATES EXESSIVE CRANKOVER ON START UP.
Tech Comments
CK CONCERN CK OASIS HOOK UP AND TEST WITH WDS.CALL HOTLINE STARTING SAME AS NEW TRUCKS ON OUR LOT
Details
10083083
E84
23
ALL STAR FORD
25283
16-MAR-05
RECAL
10628401
Customer Comments
CUST STATES ON WARM RE STARTS ENGINE SMOKES HEAVY AND ENGINE RUNS ROUGH D A OK TO REPROGRAM IF NEEDED
Tech Comments
TEST DRIVE CONFERMED CUSTOMER CONCERN.. PERFORMED EEC TEST NO CODES.. PERFORMED PERFORMANCE DIAG. STEPS 1 10...DIAG VEH NEEDING REPROGRAM REPRO FICM PCM AND TCM TO LATEST CAL TEST DRIVE CONFIRMED REPAIR
Details
13353509
06E17
35
.7
ALL STAR FORD
38926
20-MAR-06
12572902
Customer Comments
PERFORM RECALL 06E17, CONTROL MODULE RECALIBRATION
Tech Comments
D REPAIR AS PER RECALL GUIDELINES
Details
13353510
59B01
35
.3
ALL STAR FORD
38926
20-MAR-06
12572901
Customer Comments
PERFORM DEISEL ROAD TEST 59B01.
Tech Comments
1 PERFORM AS PER RECALL GUIDELINES
Details
13789059
S07
37
7.3
ALL STAR FORD
40570
11-MAY-06
3C3Z
6K682
BARM
12863001
Customer Comments
CHECK FOR METAL ON METAL TYPE NOISE FROM ENGINE AREA UNDER LOAD WHEN TOWING TECH 179 ROAD WITH CUSTOMER AND HEARD NOISE
Tech Comments
TEST DRIVE CONFERMED CUSTOMER CONCERN.. DIAG. NOISE COMING FROM TURBO AREA.. PERFOMRED DIESEL PERFORMANCE DIAG. STEPS 1 15.. PERFORMED VGT DIAG.. DIAG. BAD TURBO.. R&R HOT SIDE CAC TUBE.. R&R COOLANT BOTTLE.. REPLACED TURBO.. TEST DRIVE AFTER REPAIR.. VEHICLE RAN WITH NORMAL POWER AND NO NOISE HEARD.. CC42
Details
15987744
E72
61
.6
ALL STAR FORD
58923
02-MAY-08
9F452
16263504
Customer Comments
REPLACE EGR VALVE AS DIAG IN JOB 1. ( POWER STROKE ENGINE WARRANTY ) 100.00 DED.
Tech Comments
PERFORMED EEC TEST, P0404 & P0405. PERFORMED EEC TEST W AND EGR TEST, FOUND EGR FAILED. CHECKED OASIS, FOUND TSB 07 21 9. REPLACED EGR VALVE AS PER TSB. PERFORMED KOEO AND KOER SELF TEST, SYSTEM PASS. CLEARED CODES. ROAD TESTED, NO OTHER PROBLEMS FOUND AT THIS TIME. 072109A
