superduty4x4
I have a bunch of OBS parts I'm looking to get rid of.
4.10 open diff rear end, complete- $100
Tilt wheel 5 speed column- $40
Gauge cluster- mileage unknown, lens is filthy $50
Dash bezel- decent condition, minor damage $50
Fuel tanks w/senders- make offer
Bench seat- blue, dirty $30
ZF-5 with T-case, pedals, slave cylinder, shifters, trans hump, and wiring harness (will need repair, heat damage at the end)- $650
Core support- good condition, it got warm due to an engine fire but does not appear to be warped $200
Front leaf springs $50
Rear leaf springs- $50
Fuel selector valve- $35 (retail on these is $280+ - http://fordpartsoem.com/?i=8&act=pa...make_htaccess=ford-123&shortname=fordpartsoem)
Throttle pedal assembly- $100
Injectors- AA's, some minor heat damage to the connectors $200
Steering gear box with pitman arm- $50
Steering column sector shaft (between the column and the gear box, 2 available) $40
Rear window (solid glass), door guts, interior parts like the HVAC controls, ash tray power port etc- make offer
If someone needs engine internals (crank, rods, cam) make an offer on those parts
I also have a straight passenger side rear door ($200) a dash assembly less the bezel and dash pad, a majority of the interior trim pieces from a crew cab, brake booster/master cylinder, window glass for all doors except the driver side front door, passenger side tail light, some other odds and ends stuff as well.
I do not have any D60 stuff, sorry. No split front bench seats either.
