Oil cooler replacement..part's needed for the job?
mcdaniel1991
Germany
I'm about to order all the parts for my oil cooler but I want to make sure I get everything I need. Can someone give me a list of everything I need. Gaskets seals and what not.
mcdaniel1991
Germany
So far I have. ..
Oem oil cooler kit. 3C3Z6A632CA
GARRETT TURBO REBUILD KIT 740659-0010
STAND PIPE AND DUMMY PLUG KIT
6E7Z9A332-B
TURBO HARDWARE KIT
3C3Z9T514AG
STC UPDATE KIT 4C3Z9B246F
MOTOR CRAFT GLOW PLUGS
4C3Z12A342AA/ZD-13
UPDATED OIL RETURN TUBE
6C3Z9T515-A
Intake manifold gasket
3C3Z9439AA
So now my question is. .. is all of this needed? Anything I need to add?
mcdaniel1991
Germany
Thanks. . Already did a flash and a coolant filtration kit 10k miles ago
Sent from my GT-I9305 using Tapatalk 2
dieselmac
Unless you're having problems with the GP's, I'd leave them alone. If you do end up changing them, you might want to go ahead and get the harnesses or at least make sure your local dealer has them in stock. They get pretty brittle over time and often come apart when you're removing them.
webb06
Seneca, MO
I'd go ahead and replace the HPOP cover gasket and you'll need a tube of silicone to put a dime size drop on each side when putting it back together.
I wouldn't mess with glowplugs unless there are some bad. The harnesses can be a major pain and cost about $50 per side if you break them.
Otherwise looks like you've got everything you need.
Get a case of brake clean to clean the top part of the engine while it disassembled. They are usually nasty dirty.
mcdaniel1991
Germany
Yea im getting a code for a bad plug and I figure this would be a good time to replace it. So do you have a pn for the hpop cover seal
mcdaniel1991
Germany
Well I'm stationed in Germany lol so I can't just run to the dealership...
webb06
Seneca, MO
Oh gotcha! You had your truck shipped there?!
What year? I'll call my dealer Monday and get the part number for you
mcdaniel1991
Germany
Well there are but I can't exactly walk in and say Hey man can you get me this party haha. Also the don't have trucks in Germany so I'm sure they won't carry the part so it's just quicker and easier for me to order it.
mcdaniel1991
Germany
Ordered everything but the turbo rebuild and glow plugs now the 2 week wait.....
Sent from this scheiße post in Germany
mcdaniel1991
Germany
Welp got the oil cooler pulled today. Hope to finish the job tomorrow.
Sent from my GT-I9305 using Tapatalk 4
mcdaniel1991
Germany
Welp Its done. It started (after forever of cranking) It s running great I Scraped about 3mm of soot outta each intake port. I seem to have any leaks but I guess time will tell. Thanks for all the help.
06-sixoh
Bakersfield
Hows everything holding up? I am about to tackle this job as well, and doing all the research i can before tearing the truck apart.
