So this is what broke. .I had to drive the truck home 4 miles but I live in Germany so it takes 2 weeks to get parts. . Can I still drive it while I'm waiting or should I Park it?
Sent from my GT-I9305 using Tapatalk 2
So should I pull the oil cooler and check the screen. I guess also replace the oil cooler and use the Ipr metal hpop screen. Also I if it's not on the screen then what?
I lost a piece of the oil filter tab during an oil change at a local lube joint. Drive 400 miles no problem. Coming to a stop light it does. The piece worked its way to the IPR and 1000$ later I was running again. It's a gamble.
Yea I cant afford to gamble. I already need a new oil cooler so im going to replace the cooler and use the Ipr hpop screen. I hope the piece is on the screen.
Ok I called three big name shop's in the USA Today and they all agreed that they would just drive the truck and see if the plastic piece even messes anything up. They said it would probably toke out the IPR if anything since the hpop would more then likely chew it up. I'm pretty comfortable with doing this I just want to get a few more opinions
