6speedsd
Ok, one more question on the 2003. Have an oil leak up on top of the motor somewhere. Not a major leak, but it's definitely a leak I'd like to get figured out. The majority of the oil runs down off the back passenger side of the engine, down onto the starter. There is some oil leaking down the front towards the AC compressor. I've checked all the common spots, but can't find anything. Turbo oil fill tube is dry, turbo drain is dry, basically everything on the drivers side is dry. It's wet underneath the intake, and down around the oil cooler. He had the cooler replaced a couple years ago, and said that's about when his leak started. When we get some down time, I plan on tearing everything apart down to the cooler again and replacing orings and such. Just wanted to see if there was something else simple to check before I start tearing it apart. I'm wondering if the Oring at the base of the oil filter housing is leaking. Like where the housing attaches to the cooler. Either that or the cooler gasket is leaking. I don't have alot of faith in the guy he let do the work before. We have found several short cuts the guy took already, and I'm scared to see what I'll find if I tear into it. Sadly, that guy is a diesel mechanic.
So, anything else that could be leaking that I could check before I start turning wrenches?
