Oil leak
VA Vince
Virginia
I cannot pinpoint whats leaking. All fluid levels are good. I thought it may be power steering as I need a new gearbox but that doesn't seem to be the culprit. I have checked the HPOP and its dry all around. I had a trucks width spray on my driveway (maybe a quart) and the only place that has oil on the truck is the drivers side front wheel well. I literally have no idea what is leaking. Any thoughts on something that I am missing to look at?
2002Ford7.3
Orange, TX
Last time my drivers wheel well was covered it was the power steering lines had rubbed together and I had a pin hole in both lines.
Sent from my SM-G920V using Tapatalk
VA Vince
Virginia
Thanks. I will double check power steering and oil cooler. PS is sloppy as all get out so maybe thats it...
