Oil pressure, temp
Twan
Berthoud, Co
Was just think, if I drilled and taped the side of the oil filter housing, would that show the correct oil pressure and temps?
It would keep a clean look that way.
Alfie
Horrible state of CA
Mmmm. I guess you would. But not sure if that temp will match the temp were the EOT is at. Not sure.
jdeeg4276
Vancouver wa
I would say no. Its running off the low oil pressure pump and that's the furthest point away from the pump. Its got to drop a bit I believe. If I'm wrong sorry.
Mdub707
Mohawk NY
Why not just install one of the billet oil filter caps already drilled and tapped for such a gauge?
Cutting-Edge Diesel
Newkirk, OK
kinda hard to get to but this is out of the way
Gary
South Lyon Mi
I have a oil filter cap and fuel filter cap that I drilled and tapped so I could put a gauges on, its the easiest way to test the pressure. You'll get the pressure IDK about oil temp.
jdeeg4276
Vancouver wa
Were you looking for low/high oil psi? Should have been first question of mine.
Sent from my DROID RAZR HD using Tapatalk 4 Beta
