yzstroker11
looking to do an overhaul on my 7.3, .030 over, filled 2in from deck height, coated and balanced and i don't want to worry about blowing a head gasket ever... have seen lots of cummins use this tool to o ring the block deck. not looking to spend x on a fire ring kit(entails grooving head and block), wanting to do at home (have iskenderian cyl block groove tool). Isky groove o matic has proven to high cyl pressures since the 70's and 80's until cnc was brought up in the 90's. not looking for opinions, just seeing if anyone has done this to a 7.3
common wire .040 ss ?
genuine international head gaskets?
from my understanding it add stability to the gasket and doesn't allow floating to happen thus skipping the ageing(baked on) process that i see some people have when they replace hg?
