jban126_f350
Pulled a p0266 code don't know how longs it been in there just put remaned 190/100 injectors p0266 is cylinder 2 contribution balance but I don't have a misfire??
Is it bucking a little under a load??? I have the same code.... if I run the piss out of it... it'll stop and run perfect.
If ya wanna fix it.... yes... it's gotta come out....
Once you've determined it's not some sort of connection problem.
P0266 is a problem with the coils on the injector, could be a connection or wire problem but most time it need a new injector.
Also is it normal for the truck to buck when you tap the throttle in drive or reverse? Just lopes for a quick second then idle evens out. Again contribution test came out good buzz test passed
That could be cleared up with your tune. I run the same injectors. Would stay just a tad bit high idle it seemed..... I would tell your tuner what it's doing.
Did you get the upgraded solenoids? ??
Hmmmm.... can really hear injectors when it's running. You can hear valve train though.
You didn't hear any one loud injector when you buzzed them???
Just installed the injectors last week.
Were they Motorcraft?
They are 190/100 reman from warren diesel
Did you have the code before you installed these injectors? If not then your wiring is good and you probably need to talk to warren.
