P2263 Code
clayc_989
I picked up a 2008 not too long ago and got it loaded with a S p a r t a n tune. Seems to drive fine but every once in a while I get a P2263 code and a code for OBDII "not ready" or something similar to that.
Reading this thread I'm wondering if it is my EBP sensor or not. I cleared the code before I found the info in that thread. I checked it at idle a minute ago and I had the following:
MGP - around .3 to 1.0 sometimes negative.
EP - 14.8
VGT Duty - 95%
Could it be the sensor or do I need to check something else? Next time the code pops up I'll check these again at idle and cruise.
Thanks,
-clay
clayc_989
No suggestions? It only comes up when I'm idling...never while driving, even at relatively low speeds (sub 10mph). I took some pictures at various speeds of my DashDaq output, which I'm inclined to believe that my oil cooler is crapping out if it already hasn't.
-clay
