teambluemxer
does anyone have the screw on early 03 braided turbo feed line. im gonna be really pissed if i gotta seperate the oil cooler from housing again. :fustrate:
omg people. the early 03 6.0 log style rails. for the turbo oil feed on the oil cooler base the line actually screws on. not held on by the tab and bolt. it has a braided steel section.
Show me a pic smart guy.... My dad n I each own one.... Tore into both.... None of the turbo lines screw on at the oil cooler
Sent from my Milestone X2 using Tapatalk 2
they dont screw it... that the kind you use the same tool for the rails for.... its a STC fitting... you install the tool inbetween the black and cylinder part on top. pry down and up and it knocks loose
Probably because we don't want to go buy the tool that take the STC fitting apart.
Die grinder tool or 2 flat screw drivers will work
