ChunderDownUnder
Now , Is this right ?????
Heads nipped up (not torqued) on OEM gasket which measured around .087 thick
piston TDC on compression stroke, valves on # 1 cylinder held in place with test springs. Push down on rocker by hand and I get around .090 of travel before contact. Now if the OEM gasket has a quench .060 I take .027 of the .090 which gives me around .057 of piston to valve clearance.
