gnxtc2
What's the best way to diagnosis a bad/stuck poppet valve? Should I pull the valve covers and watch the oil coming out of the spouts?
When I first start the truck, the idle is smooth as glass. Once up to operating temp, the idle gets all choppy. If I get on the truck (highway entrance ramp), the IPR gets up to 65%, ICP +3000 psi at which time it trips the CEL, code 1211. I believe I have a high pressure oil leak.
Already swapped HPOP and IPR, same issue. Injector o-rings were already replaced. Ran CCT and buzz test with AE, all pass.
No issues starting hot or cold.
Billy T.
[email protected]
Billy T.
[email protected]
