Non - Specific
Tow-Rig
Possible to add Tow Command to a 2008 F-250 Lariat
[QUOTE="AllGo'N'Show, post: 1118633, member: 8195"] Working on this myself, picked up the TBC used in town and got a master cylinder off a wrecked truck just outside of town, now I just got to get the master cyl. installed. The truck fires up the TBC controller and cycles through, but I'm assuming doesn't see that second sensor and shuts off, I will know for sure if the programming is enabled or disabled once I have that master on then I can have them turn on the fogs at the same time. Harness for the controller is in the dash, don't need anything there. Second sensor wire for master is on the same harness loom as your current sensor, stand on your tire and look straight down and you should see it somewhere in there. EDIT: It was an option for a Lariat?? Wierd! Mine is XL so I assumed I wouldn't have it but have seen it on other XL's. I would have thought it would be standard on a lariat. [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Robfvi
Non - Specific
Tow-Rig
