Power Source for Mini Maxx
DrawDown
Spring, TX
I've searched but can't find a clear answer. I see most of you are tapping into the purple wire under the dash for powering your mini maxx. What I can't find out if this ok to use while still being able to use the factory remote start. If I read the manual correct, even if the mini maxx doesn't power on, it will revert back to the no power tune. I'm not sure if this includes no power delete tuning or no tuning at all. This is only a concern because I will be deleted. I'm doing the install this weekend so I'm trying to get everything planned and ready. Truck is a 2013. Thanks in advance.
TripleE44
Keller, TX
I'm pretty sure the mini max wont revert to the no power tune until the truck has been run three times without it powered on.
I have my power ran to the fuse box where it said to in the instructions and I remote start mine most days. Works fine and doesn't revert to no power for me.
Randy_270
Manitoba, Canada
I don't know if the 2013s are different from the 2011s but I used the white wire with a blue stripe for my ignition source and my factory comand start still works. Also the no power tune refers to no additional power added while being dpf deleted as long as you select to remove the emissions equipment.
