Hi all, first post on here. I have a 2001 f250 7.3 with 224,000 on it. I looked under it the other day to see where it was leaking power steering fluid and it looked like it was dripping off of the pump, but the pump is only 3 months old. I sealed the line going into the pump with thread lock to make sure it wasn't the fitting. Is it possible that I overfilled the res and now it's splashing around as I drive? Or is the 3 month old pump really leaking? Thank you in advance
