brian89
Driving home last night I was pulling away from the light and first and second gear were really long before they shifted, then if once they do shift they slip back out of gear if you're in the throttle even a little. Also generating a lot of heat, it didn't normally get hot just sitting at a light but if I sit at a light for 2-3 minutes it gets at least 20-40 degrees hotter, I've had plenty of trans issues in the past and this is a new one to me.
