Like the post says I had fluid under my hood by the PS fluid reservoir. I replaced the pump. Now my brakes go to the floor. I turned the wheel slowly back and forth 60 times like I read no foam coming in the system. Then bled the it from the return line going to the hydroboost Pumping the brakes and turning. The wheel. Went through and make sure all my lines are tight. Power steering feels fine now but brakes still to the floor with a half bar drop in the RPM when brake is applied. PleAse help its my daily and need it back on the road.
