Pushrod Question
GreenF350
Near Pensacola, FL
I'm gathering parts for my next big parts swap and thought I had it all figured out, but ran into an option that I didn't even know I had. Smith Brother's push rods come in two different wall thicknesses, .083" and .120". I'm guessing that the .083" ones are still stronger than the stockers and will do what I need with a set of the Comp 910 springs shimmed to 1.75" or so with a stock cam? For the price it seems like they should. :ford: Thanks for the advice.
-Aaron
hawgdoctor
king george, va.
You'd be fine with the 83's. Thats what I put in mine with a little heavier trick flow spring set, and have been flawless. If you need a set let me know. I'm a dealer for smith bros.
