Dieselboy.
What are you guys using for Pyrometer fittings, I crawled under the truck tonight and both are leaking right out of the probe hole. Autometers little thread in bung and clamp do-hicky are junk.
I have both actually.
However autometers tap in fitting is still held in with a set screw... Junk, I haave mine in the headers.
That compression fitting you show there seems the ideal solution. Know where I can buy one ?
