Question on multiple tuners and chips
PABowhunter
Just looking for more information on chips and using multiple tuners.
The Hydra: I know this can have multiple tuners on it
DP's F8: I know this chip is opened to other tuners beside DP. My question is, can multiple tuners be loaded at the same time.
TS: If you have your own burner can you pick any 6 tunes whether they're from different tuners or not? Or do they all have to be from the same tuner?
SeeYa
Georgia
You can have multiple tuners calibrations on the F8 at the same time.
SeeYa
Georgia
Awesome, thank you.
One thing about the F8, you don't need to erase the entire chip to add a new tune. So no waiting to erase the chip and reburn it. Just pick the spot you want to reburn, load the tune and hit go.
bigfords
Do you have to erase the entire TS chip each time you put tunes on it?
Powerstroker7.3
waxhaw NC
Be careful when you put multiple people's tunes on one chip cause sometimes it will not switch from one brand to the other. I know with the ts chip my truck would cut off sometimes when I tried to switch
SeeYa
Georgia
It's like flipping a switch from windows 7 and going to windows 98. Wacky things happen. Just communicate to your tuner which code you need and you'll prevent a cutting out situation
CSIPSD
Bend, OR
No issues changes between tuners on my Hydra chip, 5 different tuners on it right now...
PABowhunter
Is this true on all the platforms? Hydra, f8, and ts?
Is it a problem simply because it's different tuners? Or because your switching from different tune levels? Say going from tuner x tow tune to tuner y all out performance tune causes problems where as switching from tuner x all out to tuner y all out doesn't.
CSIPSD
Bend, OR
Its not a problem with the Hydra... Two of my tunes are even NVK, and I have no issues changing from the PMT to the NVK...
Lang
Did you get tunes from Jonathan before they stopped?
Dan V
So I have a question concerning the Hydra. My box code is PMT2, I log onto PHP's server see all the choices under VRAA6S3...pick out like 5. Stock, high idle a couple of DD's and some Tow's.
When I start the truck in the bypass, position 00, everything is fine. Back out of the drive, get going down the road...switch to a DD tune...engine dies. Roll to shoulder, cycle key to off and then it will start and run in any position. Even if I start it in 00 and switch to a tune.
All the tunes are VRAA6S3 family.
CurtisF
Running multiple tuners is fine, running different calibrations rarely works. This is why you are having issues.
For example, I can't run VDH2 and VDH5 on the same chip. Anything other than position 1 on the chip will kill the engine instantly.
dsberman94
Pennsylvania
That's normal. To use the 00 tunes you have to put the chip in 00 with the truck running then shut it off for the chip to be in bypass mode. To get it back into a tuning number start the truck take it out of 00 shut the truck off then start it again and you can use all the other numbers.
Dan V
Curtis....They are all the same hex code. The recommended hex code for PMT2 is VRAA6S3.
So it's "normal" for the truck to stall when switching from 00 to another position? I do have stock programed in at 01.
Thanks...was just wondering
dsberman94
Pennsylvania
I misread about it stalling. But now that you know about it you know not to do it.
