Big Bore
If a guy wants to use studs on an existing motor and is building another motor and wants to reuse the studs in the new motor, is there a stud that is better for, and/or is there a stud that is not recommended, doing this with?
H-11s are reusable.
So are ARPs
So are ARPs
Not only that, but after the first use, H11's have no need for a hot retorque. My studs had been used on one motor. Installed them on mine, I retorqued all of the ones outside the valve covers. Not one of them moved even a little bit. Did not bother pulling the valve covers to check the ones under there.
I reused a set of arps 4 times before. H-11 require retorque w fire rings dont think they do w plain gaskets.
If yield strength hasn't been exceeded, I agree.
What does the brand/stud material composition have to do with ensuring an even clamping force being applied to the entire head gasket surface after several heat cycles?
