Reading EGT's
Sooter6.7
Eastern WA
So guys I am deleted with mikes EGR kit and I have never been able to read my EGTS. I have purchased a H&s pyro kit since I have a MM but was told from experienced posters on the H&s forum to just go with gauges it will make everything easier.. Well I took my intake off and was going to try to put a season from the stock exhaust in my block off planet but then noticed the sensor was not plugged in. I plugged it in (to I think the throttle body) and I'm getting readings in the 1500s from a start up and letting her sit now reading mid 1300 but jumping around. Queston is are these normal temps? Should I just say F*** it and install my EGT gauge? If this is the right temp and it's working properly can I have 2 probes and read my egs on my mm from pyro and season in manifold? Thanks for any advice hoping to get this done in a couple hours
Sooter6.7
Eastern WA
Here's a pic of what I plugged the sensor into.
