RECON L.E.D.s
Spindrift
Austin, TX
My Recon L.E.D. side view mirror lenses just arrived. I tried to install them but since the OEM light socket isn't designed to go inside of the RECON lens, the way it does with the OEM lens, there is no room for the new lens to fit into the mirror assembly. Anyone else have this issue? What's the workaround?
South Florida
Its a pain in the butt, but they do fit, just takes a little finesse. Make sure you have the lights on and they are function before you fully install them otherwise you have to pop them loose and start over.
Spindrift
Austin, TX
There just seems to be too much chit to cram in the space available. ****ty design really.
Sent from my DROID RAZR HD using Tapatalk
