Tyler@Street Diesel Performance
i was wondering how you use the airdog 2 with the built in regulator to make a regulated return system ??
I think you would turn up the Airdog all the way and then set the regulator after the heads at whatever psi you want.
right i understand alot of guys are running it that way but when u put a regulator on the back side of the heads then wouldnt the 2 regs be fighting each other ?
:whs:I think you would turn up the Airdog all the way and then set the regulator after the heads at whatever psi you want.
Aeromotive or Fuellabok thanks guys by the way who makes a good regulator that is reasonably priced ? just the reg cuz the rest of the system im gunna make
You might call dozer diesel they have a rr kit they could prolly help you out
Or give us a ring. we'reready to release our kits. getting ready to have a pre-order special........
Ours is proven on a couple trucks now. Just hav't got around to putting it up yet. We have it available three ways so you can pick your setup. Pm for details.I would stick with a proven setup, such as our Regulated Return kit or the Strictly diesel kit. A bunch of people are running Both and have been for a while with no issues. Our stage 1 RR which has held psi during nitrous passes with 225 150 injectors runs 399.99 to your door for the month of march. Our Race stage 3 system with Hardline stainless feeds, returns and fuel bowl delete runs 599.99 to your door.
Keep in mind that a RR will only be beneficial until you simply need a higher volume pump. We have been more than satisfied with the aeromotive a1000 setup.
