Usually when you window a motor, you need a new one.
2 7mm bolts. One behind pw/pl switches. One behind the red reflector. Lift panel straight up put it to the side. 4 6mm head bolts and remove the speaker. Then there is 3 8mm head bolts on the window motor that you can see through provided holes gold colored heads. Unplug the motor and pull it out. Make sure when you put the new one in it lines up with the regulator so it doesnt strip the teeth.
Not sure, I would be very surprised if it had the regulator with it also. It would be a little different if you pull the whole regulator out. Even if it does have it. I would pull the motor off and just put it in.
That is dirt cheap for $51 to get both. If you want to put the regulator in. IIRC its 4 10mm bolts and then unbolt it from the glass by rolling the window half way down until you can see the bolts holding it to the glass. Make sure if you do this to support the glass some how.
I don't get it...:shrug:
He must have meant windowing a motor block. Not an actual window motor lol
