Reprogramming ACM
Goober
AZ
Curious if anyone has had any luck trying to use FORScan? 2008 6.4 about 70k miles.. factory radio out of no where lost aux input, from hours of searching.. it basically needs to be reprogrammed or turned back on.. decided to try this ForScan, yet am unable to reprogram it. It’s throwing 2 dtc’s in the radio itself. B1342 & B2477. Any help would be greatly appreciated.
Racer71
I haven’t as I always upgrade to aftermarket. I have the original nav/touchscreen from my 08 I would sell if if you’re unsuccessful.
Goober
AZ
Send me the info.. that might be an option if this doesn’t work. I do prefer the stock look, it would need to be programmed as well I assume
