caggr5
I have a 2008 F350, 6.4 and recently my reverse lights and back up sensors stopped working.
I have confirmed that all the fuses and relays are OK and that there are not wiring issues at the back of the vehicle and ground is ok.
When I pull the codes with a scanner all it does show that there is an open circuit in the reverse light. I have constant power at one of four pins when the key is on at what they seem to refer to as the reverse lamp switch (on the top left side of the transmission) but I have no idea how to test this any further??
Has anyone else had this issue and been able to solve the problem??
Any help is appreciated......
