bluedevilslax
Hey all, I am just seeing who all in running either injector and what they like and don't like. Just trying to get some insight before I make a buy. Thanks for any help.
One thing of note, in at least one case I know of, when compared with other injectors of the same size, the Rosewoods flowed less fuel for the same PW. That is not a quality issue, just something to consider. If it's a case of certain mods to the injector, and the price difference reflected it, then it's really a matter of if that amount of flow is important to you, and what you want to pay for.
Yeah, but who knows if they were comparing his budget built injectors to to a set of premium builds from Cass.
Yeah, but who knows if they were comparing his budget built injectors to to a set of premium builds from Cass. I have had injectors from both builders. Both have great customer service, never had a problem with an injector built by Rosewood, and with Cass Only had one problem with the poppets in my hybrids. Either builder you go with you will be happy.
I don't know for sure where the flow chart came from, but I'm pretty certain it came from Rosewood. Based on that, I would think he would submit flow from his best injectors.
Either way, you have just added even more info to consider when talking to Rosewood.
And the other injectors weren't from Cass, however I know his compare with the other injectors in question.
Regardless there is in fact a disparity in flow numbers between injectors of the same size, and, as I stated, this could very well be reflected in price.
I'm simply passing on information for consideration, not bashing anyone's injectors.
The only flow chart i have seen from Rosewood was for a 238, and it was being used to show the difference in flow between 238's and some other larger injecor. As far as price, Rosewood has Cass beat by $200 on the exact same injector and thats at a premium build from Rosewood for the 238 vs Cass's 238.
Cass an Matt are awesome to work with, I'm sure you'll be happy with your decisionI just bought a set of full force injectors so that's my choice but I did talk to rosewood about doing injectors and he actually recommended full force for anything bigger than a 250 just because he was busy at the time. To me that says either way you can't go wrong with who you choose.
Just my 2 cents
Just my 2 cents
Just my 2 cents
