Im gonna have to find a place that has all these abbreviations... haha um were do i need to look to find which ones they are?
ICP - Injection Control Pressure sensor located at front of drivers side head
IPR - Injector Pressure Regulator located at the back, bottom side, of HPOP
HPOP - High Pressure Oil Pump located in the front of the engine, in the valley
CPS - Cam Position Sensor located on the front bottom side of the engine near the harmonic balancer
PCM - Powertrain Control Module is your computer located by your left foot, under the dash
IDM - Injector Driver Module is a computer for your injectors located above your driver side wheel well
EBPS - Exhaust Back Pressure Sensor located in front of your HPOP
EBPV - Exhaust Back Pressure Valve is located in the exhaust side of your turbo, connecting to your downpipe
Those are the basics, you can Google stuff like "7.3 IPR location" to find pictures of exactly where it's located.
I would also go ahead and change the oil, fuel and air filters so you're starting a new cycle on everything and know when they were last changed, should be changed next, etc.
