smokinstroker
who here has jumped from an 18" wheel to a 20 or even 22? trying to see if anyone has noticed a large performance loss from the bigger rim?
Wouldnt it be a trade off if you factor oversized truck tires into the equation? A 37 on an 18 versus a 37 on a 22 cant be too much different in weight. Tires arent exactly light either.
That's kind of the way I am looking at it. I went from 16'' stock rims to 20x10s with 35s didnt notice much of a difference, even if it did lose a lil power im not worried about it. But if you are goin to dyno or anything you just swap the smaller tires and wheels back on to get your lil extra hp back.
It's all about rotational inertia, resistance to change motion. The more mass in an object, the less it responds to being pushed. The outside of a spinning object has to move much faster than the inside part near the axis.
Like we all know, this isn't weight in the bed of our truck, rotating force is on another level. You can still feel the power in my truck with 22s no question. But it takes a lot more to get those tires turning from a dead stop, once there's a motion its a lot more responsive like a stock tire truck. I could roast my tires through the gears on stock tires from a dead stop, now with 22s, they do a long chirp.
I feel like a 4 wheel launch with 22s will bypass that heavy centripetal start up feeling that big rims have, and it'll launch just like stock. I doubt this is making sense since I'm drugged up at midnight, and I usually don't even know what I'm talking about when I'm sober lol.
supposedly adding 1 lb to rotating weight is like adding 7 lbs in the bed of your truck... take it how you like not sure how true it is.
I would thinkin that if the tire size doesnt change too much the wheel tire combo wont change much either.
I know my 37.1350.20 toyo mts weighed 90 lbs each
as far as the track goes I ran a 13.02 on stock 17s with 31s then 13.19 with my 33" street tires on 22x10s....diff tracks though but similar weather, the bigger rims are well worth the look.
no doubt they arent great, but the question is how much power is actually lost.
