Runs like crap
batavia,ohio
To start out I drove down to homedepot and came back out and on the way home I notice a power decrease. It just got worse from there I finally made it home and pulled these codes. P0264,p0267,p0273and p0282. Now the injectors were in stalled 3-4 months ago and have less than 300miles on them. I also in stalled a brand new from ford injector harness. Is it my ficm or injectors.
check what the icp pressure is, also fuel pressure, load test the batteries, check ficm voltage.
batavia,ohio
Sootie I don't have a scanner that will show icp. Also don't have a fuel pressure gauge. And ficm I would have to wait till it stops raining and check it manually.
Mdub707
Mohawk NY
P0264 - low circuit injector 2
P0267 - low circuit injector 3
P0273 - low circuit injector 5
P0282 - low circuit injector 8
2,3,5,8 all share the same plug on the FICM. I would start there and ensure your harness that runs between your FICM and those injectors, is plugged in really well. Take the bolts off of the top of the FICM and push on the three plugs on the bottom, ensuring all are seated well.
See here:
Mdub707
Mohawk NY
Just get yours repaired, no need to buy a new one. If you feel the need to buy a new one however, PM if you would like to sell yours, I'll gladly take it off of your hands.
If the wire trick doesn't work, you should also run a voltage test to ensure it's the FICM itself failing.
Just so you know, that plug doesn't have to be very loose to cause these issues, I've had this happen before myself. Truck ran like completely crap, would barely carry an idle, but voltage tested perfect across the board at 48+V. I went to remove it and the center plug basically fell off, it just hadn't seated all the way when I put it on.
Mdub707
Mohawk NY
If it's a new harness, then chances are it didn't get plugged in all the way and just worked it's way loose a bit. Hopefully an easy fix bud.
Just take out the mounting bolts for the coolant bottle and you can actually pull it forward and slide the rear of it towards the drivers side fender and prop it up on top of the bracket it's mounted to, no need to drain any coolant. It should give you enough room to squeeze in there and remove the four mounting nuts holding the FICM down, lift it up and you should be able to squeeze the plugs back together. I use my left hand on top of the FICM and my right hand to sandwich the plugs in.
batavia,ohio
Yes the free fixes are especially with all the trouble I have had out of it. Like I said I have only drove it less than 300 miles since I installed my injectors thanks to my intercooler boots but I finally got that taken care of with hair spray (i hope) they didn't blow yesterday day.
