mike diesel
Bought this about 2 weeks ago to convert my s472 into an s480. Decided against it as I'm still on a stock motor. This 80mm wheel and compressor housing will turn your s400 into an s480, all that will need to be done is machine the back plate to fit the exducer of the 80mm when. The exducer is about 111mm compared to 101mm on the 72/75mm wheels.
local shop quoted me less than $50 to machine the back plate and reassemble the turbo with the new parts.
If upgrading an s472/s475 to the s480, you can still go back to the 72/75mm wheel and cover and the extra machining in the back plate will have no affect at all.
Cover has obviously been painted red and the wheel is in perfect condition. This compressor cover is a direct swap for a 72/75mm compressor cover so no changes will need to be made to your piping. I can't say for sure if it's the same as say an s464/s466. So you will need to do your homework on that one.
Looking to get $250 shipped.
