Premium Vendors
Street Diesel Performance
SDP 6.7 EGT Sensor Mount Kit
[QUOTE="Tyler@Street Diesel Performance, post: 888859, member: 5206"] [ATTACH=full]125427[/ATTACH] [ATTACH=full]125428[/ATTACH] [ATTACH=full]125429[/ATTACH] This kit allows you to mount a 2 type of EGT temp sensor probes into the right side exhaust manifold for pre turbo EGT reading. -1st side of the plate has a bung that is the proper thread to use a stock EGT sensor out of the DPF and plug in to plug the stock egr temp sensor connects into the wiring harness, both Spartan and H&S will see this probe as EGT temp using the OBD2. -2nd side is ready to be taped to 1/8NPT if using an H&S EGT kit or similar product to read EGT With the simple removal and replacement of the EGR feed pipe to the EGR coolers, these plates block EGR flow and allow pyrometer probe to go directly into the exhaust flow from the rightside manifold. This kit blocks the EGR without all the work involved in complete removal of EGR cooler and related electronics that the cooler delete kit does. Requires tuning to turn off EGR system prior to installation. [/QUOTE]
Latest: 6.0 Tech
Yesterday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Latest: ToMang07
Friday at 7:28 AM
B
No Start help
Latest: bismic
Friday at 7:04 AM
Latest: 6.0 Tech
Wednesday at 8:24 AM
Ford Power Stroke News
Premium Vendors
