04powerstroke
Once you have the four bolts removed is there any trick to remove the oil cooler from the oil cooler cover
If your asking what I think, stick long socket in hole and carefully drive out with hammer. That's how I had to get mine out when I installed a new oil cooler. Like I said be very careful since the oil cooler housing is "pop" metal, and if you hit anything important the metal will mar up very easy.
This and a set of wood blocks
Got it! The beer helped. Lol. And taping it out is an understatement.
