I ended up with a 6.0 short block assembly in garage clean out a while back.
Guy I got it from gave me a little background... it came from a truck that had normal head gasket issues...the truck owner had an aftermarket extended warranty and somehow finagled a complete engine out of the deal...block & rotating assembly is supposed to be fine.
It is still assembled at this point. I'm interested in rebuilding it for piece of mind & maybe finding a truck with a bent rod & swap em out.
What is standard when rebuilding a 6.0 bottom end? Obviously a ring & seal kit & bearings.
Vs a used engine, what is replaced or refurbished in a reman short block from ford?
Is it recommended to bore & use oversized pistons? Maybe .020"? I wouldn't really be after a big HP setup...just basic reliability. At this point I'm open for any input. Thanks in advanced
