signs/symptoms of blown gaskets?
NCPowerStroke
well i popped my hood today, to chang the oil. and i noticed my trucks coolant bottle has been puking. there was dried coolant on the battery, air filter, bottle, etc....
any how i know thats a sign, but i also had my bottle filled to the max line.
it runs great, hasnt missed a beat *knock on wood*.
but can you guys tell me what exactly i need to look/listen for?
Alfie
Horrible state of CA
First don't fill to max line. That's actually over full. Fill to the min line.
Now verify you EGR cooler isn't the route cause.
What u need to do is verify your fan clutch works, verify your ECT and EOT are in range.
Test your cap and make sure it vents between 13-16psi
Install a pressure gauge in your coolant system and see how much pressure it builds. If it reaches the pressure at which your cap vents then its head gaskets
NCPowerStroke
went out side a few min ago to start up my truck...
cranked and held key...no start
second time cranked and held key...no start
3rd time it finally started
looked in my coolant bottle..its almost drained
i have 1/4th tank of fuel so thats no problem
wtf guys? it ran great last night..
Jeremyleggett07
Katy, Tx.
Slow start can be a number of things. Do u have anything that can be used to monitor different points? Are your batteries good? FICM holding around 48v KOEO, while cranking and KOER
Alfie
Yup you need to monitor pids during the concern.
Icp
IPR
Ficmmpwr
Ficmsync
Rpm
Sync
Injector PW
ECT
EOT
NCPowerStroke
i thought it was batteries also...
but my degas bottle is covered in dry coolant from where its been puking. i filled it back to the min line. i checked oil and it was fine.
i then finally started it and went to the tail pipe, and a little puff of white smoke came out
Jeremyleggett07
Katy, Tx.
White smoke is not always a sign of blown gaskets... There is numerous reasons for that. Puked coolant can be from over filling degas bottle, or needing the updated cap as well. Pressure test ur coolant system ... Or get something to monitor ur EOT and ECT temps.
the chad
Also listen for a tea kettle sound on acceleration or slightly after. Mine was venting after a 2100 rpm acceleration
ncdzl
Where in nc are you? I may be able to help you in pinpointing this issue if you're not too far away
