RedSmokey
Who out there is running a single battery? What did you do/change to run it (as far as cables or relocation all together)? Also what kind/size of battery do you run and what CCA is it rated at? Any pics would be nice too.
I run a single group 31 with 900 or so cca. I run 2/0 from the battery to the starter and 2 from there up to the starter solenoid. One thing is my truck is ether start. If I did it again I'd run one group 8d with 1400 cca
Why do you need ether to start your truck?
Screw a single... I'm about to go duals and just go to one side or to the frame rail.
Singles are fine if you don't need the truck as a DD but I'm going to be adding a second group 31 and isolating the glow plugs on one of them.
I've seen a few with aftermarket bumpers put the batteries in the bumper. It looked pretty clean and out of the way.
So, you're going to run a battery JUST for the glowplugs?
