GCncsuHD
I have had an issue with my 2000 F250 7.3 6 speed ever since I installed the PHP 6 pos. chip. When I am in either the 80DD or 140Extreme modes and at moderate to WOT if I let off to shift the engine will rev another 2-300 RPM. Even if I roll into it in gear then let off quickly there is a ~1 second delay before the truck slows down. Same if I rev in neutral, it will jump RPMs higher after I let off. The 40 tow tune does not seem to do this at all, as soon as I let off, it lets off. The issue is more noticeable in the 140 tune than the 80. The truck is otherwise stock other than exhaust/intake.
I have driven my brother's 7.3s in the past, both an auto with banks 6gun, and a 6 speed with a TS. Neither of them did this on their highest settings that I can remember. I also asked a friend of mine with a 7.3 6speed and a TS, his does not do this either.
I signed up and asked this question on PHP's forum, and this is the response I got:
I asked if there was any potential remedy to the issue, and I got nothing.
It seems to me there should be some way around it if these other trucks do not appear to have this issue on similar power levels. Any suggestions or am I stuck either waiting a second or so to shift, or looking like I missed a gear every time I do shift? If this was normal, I would assume I would have read about it somewhere, but in all my searching I have never seen it mentioned once.
Yes, it's due to the injection pressure regulator's response time (not that there's anything wrong with it). The amount of injection pressure required and the high pressure oil pump's lack of ability to keep up with the demand causes the pressure regulator to close a lot....thus causing the delay in injection pressure drop when releasing the accelerator pedal.
