Ok, I know this subject seems to have been covered pretty well. But this truck is kicking my azz.
It takes a good 20 seconds for it to build high pressure oil both hot or cold and then runs fine.
My IPR shows 85% when cranking and once the icp comes up the truck fires up and the IPR drops to 30% and ICP is equal to desired. The ICP varies by throttle when driving and matches desired and it still runs fine.
The only odd thing is that the lp dummy gauge drops off when at idle and cranking.
I purchased the IPR leak tool and ran it up to 120psi with no sign of a leak from either valve cover or by the pump itself. If there is a leak it is not audible by my ears.
I did the oil filter fill check and it takes about 10-11 seconds to fill with the drain back pushed down.
I replaced the LPOP, lp regulator, IPR, LP oil switch, and ICP in the last week.
In march the oil cooler, IPR screen, and EGR ****** were installed.
Also this happened suddenly two weeks ago. Stopped at the DR office and it just decided it didn't want to start after. Then as soon as it was towed home it ran. From now on it takes a long crank and even sometimes won't start.
Before that it would bust off within 3 to 4 seconds and the dummy gauge never dropped off.
I am almost to the point of taking it in to the stealership and just get ready for the raping.
The truck is a late 04 with 210k with the ICP in the valve cover.
Stock turbo, stock sticks,.
Any help is greatly appreciated.
