Smoke in Cab on Acceleration
Mesa, AZ
I get exhaust smoke in the cab on hard acceleration (when the turbo kicks in). I don’t see anything obviously loose. Any suggestions?
Check the up pipes for leaks, guessing it’s got aftermarket exhaust, check where the down pipe slips together, exhaust manifolds, ebp tube. Those are all common spots. Another thing to do is put it in the smokiest tune you have and have someone power brake it while you’re checking under the hood for smoke coming from anywhere
